S5 Huge Battery Drain
RiverJulia
4
So I got an s5 a month ago and I was super excited about the battery life, because supposedly it's supposed to last a whole day. Now I'm a teenager and I'm on my phone quite a bit. I'm almost always on wifi though. I have my screen on auto and I always close all my tasks. I also have a battery saver downloaded, so I feel like I'm relatively good about saving power. But when I go into my settings and look at my battery life it says that I have 2 hrs on y
65%. I'm so confused and I would pretty much do anything to get a better battery. I'll put an screen shot of my batter stats below. Thanks!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,542
4,675
113
Welcome to Android Central! It would help to wait until your battery is down to 20-30% after a full charge (without any charging in between), and then show us the main battery screenshot, the full size battery graph (to see Awake time and cell signal quality), the Screen category (to see total screen-on time), and the Cell Standby category (to see Time without Signal). If your cell signal is poor, battery can drain faster, since the radio is working harder to get a signal.
I would advise against manually closing apps, or using battery saver apps that try to save battery by killing apps. This can be counterproductive, since many apps will often open automatically, and the constant cycle of opening and killing and reopening can use more battery. Just allow the system to manage your memory. See these articles for more info:
RAM: What it is, how it's used, and why you shouldn't care | Android Central
http://forums.androidcentral.com/ambassador-guides-tips-how-tos/380592-guide-ram-android.html
Other general battery saving tips here: http://forums.androidcentral.com/am...how-tos/298919-guide-battery-saving-tips.html
RiverJulia
4
I can't find the cell standby category, so I hope this is enough...
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,542
4,675
113
LOL, no worries, you're not [rear-end]-ing in.;) We like as much community participation as possible!
Yes, the main battery stats screen would still be helpful at this point. What I can tell so far is that you use your phone pretty heavily, and you look like you're on track for 4.5-5 hrs of total screen-on time. I don't have an S5, so I can't say for sure, but that's pretty good for most phones. My old Razr Maxx (with the monster battery) would give me around 5 hrs of total screen-on time at the most.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,542
4,675
113
If you're using the phone non-stop with the screen on, then yes. That's probably about the same as using an iPhone non-stop with the screen on.
STARGATE
Ambassador
Oct 8, 2012
6,660
62
48
So basically I can get like 4 or 5 hours on it while I'm actively using my phone?
About right, I have the GS5, also got it about a month ago. Great phone!
Battery is way better than my GS4, and the best out of all my previous smartphones.
Welcome to the forums at Android Central Julia! 🙋
Sent From Another Galaxy
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,542
4,675
113
Sure, but keep in mind that they usually require a new battery cover, since extended batteries are thicker than the stock ones.
Chelsea rae
