+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default Micro SD card problem
    Hello all, im currently experiencing a very frustrating problem with the SD card on my LG G3. I have a samsung pro 64GB class 10 card. I can put a certain amount of music on it roughly about 2-3gb and then all off a sudden there comes a point where the phone does not respond to the computer and it just freezes. When i disconnect it from the computer i cannot access any of the files on the phone and in most cases i cant even perform a restart without it freezing. I need to take the battery out in order to restart and when i do this the phone does not mount the SD card. When i connect to my computer i cant access the SD card files as it cannot be mounted. However the phone does allow me to erase all the data and then the SD card is recognised and i am able to once again sync up to my pc and start adding files. I thought it may be some corrupt files however after running some scans on them nothing shows up. Can someone please help?
    Thanks
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,684 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Micro SD card problem
    Duplicate post--see this thread for response: Micro SD card problem
  1. Recovery Boot Loop Problem
    By rspilot1 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 09-22-2016, 02:46 PM
  2. Problem syncing contacts on Samsung S5 with Exchange 2003
    Last Post: 10-18-2014, 10:56 AM
  3. Problem: GPS "On" but will not register moving location...
    By blackdogAC in forum Samsung Galaxy S4
    Last Post: 07-30-2014, 07:20 AM
  4. nexus 10 problem
    Last Post: 07-28-2014, 12:14 PM
  5. Samsung galaxy Xcover 2 root problem
    Last Post: 07-28-2014, 10:17 AM
