1. AC Question's Avatar
    Hi
    I have aproblem with my S4.
    No sound at all. Not in the speaker, Not in the Ear phones and not at the Ear of the mobile.
    I think it is since i update the HW and Fremware.
    How to Do a hard Reset ? what can be the problem. which part is it ? where is the Audio processor on the S4 board.
    Does anyone has a boars parts description ?
    Thanks
    yoram
    [emal removed by Moderator]
    07-29-2014 06:36 AM
  2. note3owner's Avatar
    Sometimes merely a reboot works. There may have been a problem with the sound card failing to initialize.
    If that doesn't help, and if you are still under warranty, go to samsung.
    Else
    Try a factory reset
    Backup all your contacts, pictures and important data.
    Get into recovery mode (check it on Google how to, its on a per phone basis, but usually pressing all physical buttons works)
    Then wipe data in recovery mode.
    07-29-2014 08:18 AM
  1. S pen on cyanogenmod?
    By note3owner in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 08-08-2014, 10:10 AM
  2. Stuck on 4.2.2 Verizon
    By mhellesen in forum Moto X (2013)
    Last Post: 07-31-2014, 04:48 PM
  3. Google loading problem
    Last Post: 07-30-2014, 04:10 AM
  4. Replies: 1
    Last Post: 07-29-2014, 08:33 AM
  5. Samsung S3 is making me sick!
    Last Post: 07-29-2014, 07:18 AM
