1. Unregistered's Avatar
    I dropped my samsung galaxy s4 in water now the battery drains way too fast. Is this a battery issue or a hardware damage issue? How can I fix this?
    07-29-2014 08:52 AM
  2. Almeuit's Avatar
    It could be hardware or the battery itself. Try a new battery and see if it helps.
    Sent from my T-Mobile Note 3 using AC Forums.
    07-29-2014 08:57 AM
  3. Slashyou's Avatar
    Well it is probaly most likely the battery it self.
    BUT batterys are DIRT CHEAP! 2,99 dollars for a new battery: Amazon.com: Samsung Galaxy S4 Replacement Battery (2600mAh): Cell Phones & Accessories
    BEST LUCK TO YOU AND YOUR PHONE!
    07-30-2014 05:36 AM
  1. Can't Find Saved Places after Google Maps Update
    By TJGEsq in forum General Help and How To
    Last Post: 07-30-2014, 05:16 PM
  2. Replies: 2
    Last Post: 07-29-2014, 12:45 PM
  3. Back panel Damaged
    By Kasi14 in forum HTC One M8
    Last Post: 07-29-2014, 11:13 AM
  4. Back panel got damaged
    By Kasi14 in forum HTC One M8 Accessories
    Last Post: 07-29-2014, 04:10 AM
  5. blu life 8 phone
    Last Post: 07-29-2014, 12:28 AM
