1. AC Question's Avatar
    ok so my fone is about a yr old,,but wont hold the battery charge,,have tryed a few things but tonight i have done a full restore on it,,,wiped the lot,,started afresh..when i go into my battery-usage it shows my android system is using 100%,,does this mean my android system is draining my battery to quick?
    07-29-2014 05:15 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone do you have? Checking battery stats after only a short period of usage gives you a skewed picture, so wait until the battery is down to 20-30%, then show us screenshots of the following:
    1. The main Battery screen.
    2. The fullscreen battery graph screen (to see total Awake time and cell signal strength).
    3. The Screen category (to see your total Screen-On time).
    4. The Cell Standby category (if present, to see your Time without Signal).
    If you have a removable battery, it could be starting to fail. You could try a new battery. Or a quick and dirty test is to remove the battery, place it flat on a table, and try to spin it--if it spins freely, it's bulging in the middle, which is a bad sign. But even if it doesn't spin, it may still be worth trying a new one.
    07-29-2014 07:14 PM
  1. Power saving mode issue
    By Tyler_13 in forum Samsung Galaxy S5
    Last Post: 07-19-2016, 10:33 PM
  2. I keep running out of memory on my Nextbook 8
    By JT Peters in forum Other Tablets
    Last Post: 02-06-2016, 02:30 PM
  3. Loss password and finger print cannot identify
    Last Post: 07-29-2014, 08:09 PM
  4. End of unlimited data coming
    By donc13 in forum Verizon Samsung Galaxy Note 3
    Last Post: 07-29-2014, 02:57 PM
  5. Replies: 1
    Last Post: 07-29-2014, 12:07 PM
