1. Veronika Zamorano's Avatar
    Hey guys so I've had my LG Optimus F6 for about a year and have had my SD card about 6 months. Just recently whenever my phone turns off or dies all the apps that were on my SD card won't reinstall. This is becoming very frustrating because I then have to remove them and then reinstall them!! Is there a problem with my SD or the phone? Or is there a way I can reinstall them easier?? Is there a way to keep this from happening??
    07-30-2014 07:33 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The easiest test would be to try another SD card, and see if the same behavior occurs. An easy workaround would be to avoid having the phone die, which is not a good idea in general, because it puts the battery at increased risk of total discharge (which means it's irreversibly dead). There's really no reason to power a phone completely off these days either, so just put it to sleep when you're not using it.
    07-30-2014 08:39 PM
  3. Veronika Zamorano's Avatar
    It only dies every once in a while other times my I go to use my camera and it says SD card not mounted so then I turn it off and try that way if not I actually have to reformat it
    07-30-2014 08:42 PM
  4. B. Diddy's Avatar
    If your SD card does that, it could be a bad card, or the phone's SD slot or interface might be faulty. Trying a different SD card would help to sort that out.
    In the meantime, you could consider installing SD Insight, which can tell you the details of your card, and let you know if it's actually what it says it is. Counterfeit SD cards are somewhat common these days, so if the app tells you something radically different than what's on the card's label, it's probably a knockoff.
    07-30-2014 08:49 PM
  5. Veronika Zamorano's Avatar
    Awesome thank you!
    07-30-2014 09:01 PM
  1. SD card column??
    By Peripera in forum Samsung Galaxy S4 Mini
    Last Post: 08-01-2014, 01:39 PM
  2. Replies: 2
    Last Post: 07-30-2014, 05:58 PM
  3. phone alerts for no reason
    By jess1t77 in forum Samsung Galaxy S5
    Last Post: 07-30-2014, 04:22 PM
  4. Unable to reply or forward in g-mail
    Last Post: 07-30-2014, 04:20 PM
  5. Problems after 6 months
    Last Post: 07-30-2014, 04:16 PM
