+ Reply
Results 1 to 6 of 6
    AC Question
    AC Question's Avatar
    Guest
    Default "Downloading...do not turn off target" HELP HELP HELP
    My phone has been acting weird for the past couple hours. It's a Samsung Galaxy S4. It started saying that it was connected to a dock, which it wasn't. Then it said it was connected to the PC, and it wasn't.
    Then it started dying, so I plugged it in to charge, and it just kept dying and dying. It said plugged in, but it wouldn't charge. So I turned it off because I figured it could charge like that. I left the room and came back to the Android dude on the screen and it says "Downloading do not turn off target" and some words up in the left corner.
    I don't know what to do and I NEED my phone. I'm in the process of finding a job.
    Any help would be great.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: "Downloading...do not turn off target" HELP HELP HELP
    Try pulling the battery for a few minutes.
    Signed, an M8, Liquidsmooth, and the AC Forums App
  3. #3
    I tried that. And pressing every button every which way. I even downloaded Odin, but I can't find the tar.md5 file to extract.
  4. #4
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Quote Originally Posted by megxn View Post
    If you know your model number, you can download them from sammobile or samsung updates .com
  5. #5
    I'm on samsung updates . com but how do I download the file?
  6. #6
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Search by model number in the drop down menu.
  1. Hancom Word 2014 July download - now program won't work
    Last Post: 03-13-2015, 08:49 AM
  2. Email Does Not Update Automatically!
    Last Post: 08-02-2014, 11:20 AM
  3. SD or phone problem? PLEASE HELP!!
    By Veronika Zamorano in forum Ask a Question
    Last Post: 07-30-2014, 10:01 PM
  4. HTC backup account not backing up daily
    By jcdub in forum HTC One M8
    Last Post: 07-30-2014, 07:33 PM
  5. Replies: 0
    Last Post: 07-30-2014, 07:02 PM
