1. shubin8's Avatar
    I am using Moto g xt1033. I've upgraded my phone last week and after the upgrade my battery is losing its juice a lot earlier than before. I've already wiped cache partition and followed other basic things but didn't help me. Haven't done a factory reset yet as I have some very important data. Suggestions or help will be widely appreciated. Thanks.
    07-31-2014 06:13 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you show us some screenshots? Charge up to 100%, then use it normally until it's down to 20-30%. Then post the following screenshots:
    1. The main Battery stats screen.
    2. The fullsize battery graph (with awake time and cell signal strength).
    3. The Screen category, to see total screen-on time.
    4. The Cell Standby category (if present) to see time without signal.
    anon8380037 likes this.
    07-31-2014 01:03 PM
  3. prasadbulusu's Avatar
    Hi B. Diddy,
    I am using Moto g xt1033. Got it from flipkart yesterday with 4.4.2 in it. Updated to 4.4.4 as soon as I recieved it. Now my battery is really draining quickly. I keep the 2G internet ON throughout, but I dont browse that much. I use it for whatsapp and facebook. I play games like candy crush saga and smash it. battery drained fron 100% to 20% in 8 hours. screen brightness is in auto mode. What is the problem here. If I do hard reset, will there be any improvement in batery performance??
    Thankyou for taking patience to read this and responding.
    08-05-2014 01:21 PM
  4. belodion's Avatar
    From 100% to 20% in 8h doesn't sound too bad to me, especially if you had quite a high screen-on time, say 3 or 4 hours. Screenshots of the stats requested above would be very helpful.
    08-05-2014 01:30 PM
  5. anon8380037's Avatar
    Try going to Google account settings with master sync on, and un-check most sync options for a while, especially photos. See if it improves, then turn them back on one at a time. No scientific reasoning, just a hunch of mine. On a major update, like from Jelly Bean to KitKat, Google overrides your previous settings and preferences and resets everything the Google way.
    Sent from my SM-N9005 using Tapatalk Pro
    08-05-2014 01:56 PM
  6. Javier P's Avatar
    100% to 20% in 8h is too fast for a Moto G. Post the screen shots that Diddy said and we can see the culprits. My bet, Facebook and Google +.
    Set notifications and updates to manual in Play store.
    Moto G from ACF
    08-05-2014 02:16 PM
  7. anon8380037's Avatar
    Yes. How did I forget Google +.
    08-05-2014 02:55 PM
  8. Prem Ssn's Avatar
    I'm using moto g 2nd gen...my battery dries within 5hours.even in normal usage..suggest me what to do??
    10-26-2014 02:38 AM
  1. Replies: 1
    Last Post: 09-28-2014, 05:51 PM
  2. Battery drain
    By wolfman7828 in forum T-Mobile Samsung Galaxy S4
    Last Post: 08-01-2014, 05:35 PM
  3. Media Server Using Battery Whilst Playing Spotify
    By tshirttan408 in forum HTC One M8
    Last Post: 08-01-2014, 01:46 AM
  4. Moto G
    By Julio Noronha in forum Ask a Question
    Last Post: 07-31-2014, 05:06 AM
  5. Can indian bough dual sim MOTO G work in Uk on a UK based sim
    By Sanjay Mital in forum Moto G (2013)
    Last Post: 07-31-2014, 03:27 AM
