+ Reply
Results 1 to 6 of 6
    AC Question
    AC Question's Avatar
    Guest
    Exclamation Wifi problem on Samsung Galaxy Note 2 after update
    After updating my phone yesterday morning, I am no longer able to connect to any wifi connection. I have tried at work and at home. When I select the network it says "Connecting", "Authenticating" , "Obtaining IP Address" , "Checking the quality of your internet connection", "Turned off" in the area that it shows if a network is not in range, connected, etc. I hadn't ever had this problem before the update and the network connections are working on all other devices. I have tried the *#0011# short code, didn't work. I have tried forgetting the networks and restarting my phone then reconnecting, still didn't work. Please help! This is killing my data!
  2. #2
    Almeuit's Avatar
    Posts
    Global Posts
    23,292 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Wifi problem on Samsung Galaxy Note 2 after update
    Go into your wifi settings.. Click the menu button and then go to advanced. Once there turn off "auto network switch" and it should help.
    Sent from my T-Mobile Note 3 using AC Forums.
    Attached Thumbnails Attached Thumbnails Wifi problem on Samsung Galaxy Note 2 after update-1406829019255.jpg
  3. #3
    Chelsea Reid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No luck..
  4. #4
    Miguel Paulo Marcos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How to reset my Android to JellyBean?
  5. #5
    srfinc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    If on a home network wifi go into your modems administration page via PC and add your Note 2 MAC/IP address (found in settings under about phone)to allowed devices sections and it will automatically connect and stay connected.
    Sharky Roe
  6. #6
    sand75's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    these solutions didnt work for me.
  1. Replies: 1
    Last Post: 12-26-2015, 09:57 PM
  2. Rooted GT I9505 // Update from 4.3 to 4.4
    By ambalto in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 04-17-2015, 07:11 PM
  3. Picture on Contacts
    Last Post: 09-07-2014, 02:35 AM
  4. Replies: 1
    Last Post: 07-31-2014, 01:20 PM
  5. LG G2 Ringtones on root
    By Unregistered in forum Ask a Question
    Last Post: 07-31-2014, 12:20 PM
