+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default Sound is full but is low
    Hi,
    i have had my GS5 for about a week, and today when i was listenting to music i tried to turn the volume up and the symbol said it went up but now is really quiet. And now it isnt just the music but every thing, i have check the inside all the indicators are white, and i have no idea what to do i have been through all the sound settings and it says it is at its max.
  2. #2
    warn joe's Avatar
    Banned
    Posts
    Default Re: Sound is full but is low
    Quote Originally Posted by AC Question View Post
    Hi,
    Well, are you experiencing the problem when you are listening over the earphones or its something different ?? Anyway in both case that's weird I would say why don't you try heading over to the nearest support for fixing as its looks the problem is some where over the hardware, i think the device might be suffering from some manufacturing defects. And we can't guide you on fixing it, I am sure you will be having an active warranty. So try heading directly over the nearest support and seek for replacement.
  1. Trying to boot into recovery mode but it says " installing system update"
    By izzydoesit in forum Verizon Samsung Galaxy S4
    Last Post: 09-17-2015, 06:31 AM
  2. Replies: 18
    Last Post: 08-05-2014, 03:06 PM
  3. Replies: 1
    Last Post: 08-01-2014, 01:48 AM
  4. Can't see Favorites is list mode after update
    By ldemayop in forum Samsung Galaxy S5
    Last Post: 07-31-2014, 08:37 PM
  5. After reboot - Changes back to Sound Mode from Vibrate Mode
    By postbold in forum Samsung Galaxy S4
    Last Post: 07-31-2014, 05:50 PM
