1. AC Question's Avatar
    I am having an annoying issue with bluetooth (sony MW600) playing media audio on my Droid Maxx stock 4.4.4. I have been using the same set up for over a year.
    All of the sudden when I play media audio it just plays on the phone speaker and will not play on the bluetooth no matter what I try. Phone calls work fine on bluetooth as they always have. Phone audio and Media audio are both checked. I have tried another bluetooth device and the problem is the same so I am sure that the phone is to blame. I have also done a wipe memory cache, unpaired and repaired the bluetooth. I usually use beyond pod for must of my media audio, but it is not the problem as the problem seems to be with all media audio, youtube, google music, pandora, iheart.
    I have not tried a factory reset, mainly because I am not sure what will happen to all of my apps and current phone settings.
    Thanks in advance for any help with this.
    08-01-2014 11:11 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you tried those headphones on another device? Maybe the headphones are failing.
    08-01-2014 12:04 PM
  3. Brian Weist's Avatar
    I have tried another bt headset and the problem is the same, so I am pretty sure its the phone since it has the same issue with multiple bt devices.
    08-01-2014 04:32 PM
  4. B. Diddy's Avatar
    Oh sorry, I think I missed that. When you say you wiped the memory cache, do you mean you wiped the system cache partition or the individual app caches?
    08-01-2014 05:55 PM
  1. Replies: 1
    Last Post: 08-25-2014, 07:48 AM
  2. New to MAXX - is Tasks app and widget gone?
    By Jeffrey_L in forum Motorola Droid MAXX
    Last Post: 08-03-2014, 10:01 PM
  3. Replies: 1
    Last Post: 08-01-2014, 10:44 PM
  4. Google Play Store wont load Galaxy S5
    Last Post: 08-01-2014, 10:29 AM
  5. feedback 2 caller when using bluetooth headset
    By Nedra E in forum Google Nexus 5
    Last Post: 08-01-2014, 10:04 AM
