+ Reply
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Almeuit
    AC Question
    AC Question's Avatar
    Guest
    Default Samsung Note 3 Battery Problem
    I bought Samsung Note 3 , 2 weeks ago
    after download basic apps (Fb,whats-app etc..)
    i lose 1% form battery life in just a 2 minute ,Dose this applicable with just device
    i need advice to save the battery live best way to stop background apps,
    and i ask if there is away i can check if there is a problem with the battery it self
  2. #2
    Almeuit's Avatar
    Posts
    Global Posts
    23,292 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Samsung Note 3 Battery Problem
    You would have to look at your battery stats after a day of usage. It will help to tell you what has been using the battery. An example is below.
    Sent from my T-Mobile Note 3 using AC Forums.
    Attached Thumbnails Attached Thumbnails Samsung Note 3 Battery Problem-1406942875480.jpg
    UJ95x likes this.
  3. #3
    Mahmoud Ahmedcs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    this is what i have now,
    but i think 1% (using Wifi ) in 2 minute is a bad !
  1. Samsung Galaxy S5 Sm-g900h work in Japan?
    Last Post: 08-18-2014, 08:22 AM
  2. Replies: 5
    Last Post: 08-02-2014, 12:31 PM
  3. Samsung Grand Duos i9082 won't turn on
    By Mark Alfabeto in forum Ask a Question
    Last Post: 08-01-2014, 08:46 PM
  4. HTC one M8 launch bar problem
    Last Post: 08-01-2014, 08:16 PM
  5. S2 Camera Problem (HELP)
    By Kenn Mondina in forum Ask a Question
