1. Kevin Deuel's Avatar
    Ok so a few days a rooted and flashed my Galaxy S4 SGH-I337M with Cyanogenmod CM11 I love it and it has improved battery life over all however I have ran into some unexpected bugs (I just got an update today moving me to 4.4.4 by the way) firstly I noticed that a bluetooth process was running and draining between 61 to 62% of battery I refreshed the list and now it shows that the screen is draining 61 to 62% and that doesnt seem normal as I have the screen set to auto and it is dimmed almost all day. Does anyone have a direct answer as to why it is doing this is it a bug in the software or do I have something setup wrong in the settings. Thank you all in advance and a look forward to your responses.
    08-01-2014 11:16 PM
  2. UJ95x's Avatar
    It's nothing to be worried about. It just means that from the battery you HAVE used, 61% of it has gone to the screen. If you're constantly using your phone that will always be the case.
    At the moment, mine is also at 61%.
    Sent from my Galaxy S4 running SOKP 4.4.2
    Kevin Deuel likes this.
    08-01-2014 11:20 PM
  1. GS3 Shuts Down Due to Dead Battery but Battery is NOT Dead!
    By wowzem in forum Sprint Galaxy S III
    Last Post: 02-11-2015, 08:47 AM
  2. Replies: 2
    Last Post: 12-23-2014, 08:17 AM
  3. Replies: 1
    Last Post: 08-01-2014, 10:58 PM
  4. Galaxy tab 3 - apps won't run (drop out to main screen)
    Last Post: 08-01-2014, 10:20 PM
