+ Reply
Results 1 to 4 of 4
    AC Question
    AC Question's Avatar
    Guest
    Default led lights
    is my alcatel one touch pop c1 compatible with any led lights for notification?
  2. #2
    STARGATE's Avatar
    Posts
    Global Posts
    9,223 Global Posts
    Carrier
    None
    Default Re: led lights
    I'm not familiar with that device but Light Flow from the Play Store works with plenty of devices.
    I used to have it on my Motorola Photon 4G.
    Try it and let us know how you like it.
    Sent From Another Galaxy
  3. #3
    If it has an Led notification light, then yes.
    Sent from my Nexus 5 using Tapatalk
  4. #4
    Generally based upon the needed requirements, The mode of selection will be depended. In these aspects, We must consider the high quality of LED strips which will help us to give more brightness while compared to the normal one.
  1. LG G2 Blinking Red LED
    By CarnCarnage in forum LG G2
    Last Post: 06-27-2016, 03:15 PM
  2. Replies: 1
    Last Post: 09-28-2014, 03:05 PM
  3. Light is on, but not charging when plugged in
    By Jason Eddy1 in forum Ask a Question
    Last Post: 08-01-2014, 10:55 PM
  4. Screen - Light bleed / leak?
    By blink1me82 in forum LG G3
    Last Post: 08-01-2014, 12:19 PM
  5. Replies: 2
    Last Post: 07-31-2014, 08:13 PM
