+ Reply
Results 1 to 3 of 3
    AC Question
    AC Question's Avatar
    Guest
    Default phone problem
    i have a galaxy ace gt-s3850i and it keeps giving a sign that it's charging when it's unplugged in charger and sometimes it gives the sign then goes and so on
  2. #2
    STARGATE's Avatar
    Posts
    Global Posts
    9,223 Global Posts
    Carrier
    None
    Default Re: phone problem
    Clear cache and reboot, see if that helps. It could also be a bug, did you have a recent software update?
    Sent From Another Galaxy
  3. #3
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    You could also just have a bad cable. Try using a different one and see if the issue persists.
    Sent from my Galaxy S4 running SOKP 4.4.2
  1. controlling google play on my 7 using my I phone?
    By macman4 in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-03-2014, 04:23 AM
  2. phone key ad
    Last Post: 08-02-2014, 06:22 PM
  3. phone isnt showing signal
    Last Post: 08-02-2014, 05:59 PM
  4. Replies: 1
    Last Post: 08-02-2014, 04:04 PM
  5. Mic problems on LG G2
    By Harold Briedenbaugh in forum Ask a Question
    Last Post: 08-02-2014, 03:04 PM
