1. AC Question's Avatar
    I accidently dropped my phone when going to sit down,
    When it hit the floor the back case released and the battery fell out,
    I turned it back on and my battery icon has some dead pixels, And when I turn the phone off, Those dead pixels go along with the screen,
    Im now losing 1% every minute.
    Is my battery damaged?
    Should I get a repair?
    As a bit of extra useless info - The phone fell onto a wooden floor not very hard.
    08-03-2014 02:13 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Unless that wooden floor was carpeted, it's still a hard surface, so some damage could have occurred. What phone do you have?
    First off, it sounds like the screen may have been damaged a bit, if you're seeing some dead pixels. Watch that closely--it can start to spread until much of the screen is unusable. If that's the case, you'll have to replace the screen.
    For the battery, take it out, place it on a flat surface, and try to spin it. If it spins freely, it's bulging in the middle, which means it's failing. In any case, try a new battery, because if the new battery doesn't drain like that, you know your current battery is having a problem.
    08-03-2014 02:35 PM
  1. Replacement phone box?
    By Cinzz in forum Ask a Question
    Last Post: 12-07-2014, 06:28 AM
  2. Replies: 2
    Last Post: 08-10-2014, 01:27 PM
  3. Used phone problem
    By Infinite Jest in forum Verizon
    Last Post: 08-05-2014, 02:02 PM
  4. phone contacts not showing on Gmail
    Last Post: 08-03-2014, 11:07 AM
  5. Qi charging getting phone hot?
    By Nyvideo in forum LG G3
    Last Post: 08-03-2014, 09:48 AM
