+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default Nexus 7 problems casting screen to Chromecast
    Today I decided to try the screen casting option for my chromecast. It did not work. I get two types of error messages. The first is when I go through the chromecast app is it says "disconnecting" really fast and nothing happens. The second option is when I try it from the pull down menu it says "connecting to (blank) has failed."
    I have done the following things:
    Factory reset of chromecast
    chromecast is at version 1.7.4.
    I tried uninstalling and reinstalling the app and powering off the devices
    android tablet is at version 4.4.4
    I am beginning to think my chromecast or tablet may be a dud. Any help is appreciated!
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,890 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 7 problems casting screen to Chromecast
    Does your Chromecast otherwise work with other apps or devices?
  1. How do I move apps from internal storage to SD card
    Last Post: 01-23-2015, 03:12 AM
  2. Disable Screen wake on Headphones plugged in ?
    By Iriez in forum Samsung Galaxy S5
    Last Post: 09-07-2014, 08:07 PM
  3. Which Android TV Stick/Box To Buy?
    By Jack Carver1 in forum General News & Discussion
    Last Post: 08-09-2014, 06:35 PM
  4. Replies: 2
    Last Post: 08-03-2014, 06:59 PM
  5. Can't change lock screen security
    By tylermc7 in forum Samsung Galaxy S5
    Last Post: 08-03-2014, 05:39 PM
