1. Jr Lagos's Avatar
    Good afternoon, I have a sort of problem in YouTube. How can I block those nasty porn videos in YouTube?
    Do you have any suggestion or do you have any Apps that will block those videos in YouTube.
    08-04-2014 01:55 AM
  2. Indoler's Avatar
    Wow, you found "nasty porn videos" in Youtube? You must have been looking real hard then!
    Can you post the URL to one of those "nasty porn videos" here to show us what you mean?
    I've never found even a nipple in Youtube. Let alone "nasty porn videos". And trust me, like you, I've looked hard too!
    If you find videos in Youtube that you object to you can report them to Youtube. That will block them. IF they are indeed "nasty porn videos".
    08-04-2014 03:51 AM
  3. davidnc's Avatar
    08-04-2014 04:06 AM
  4. Jr Lagos's Avatar
    How can I find the URL?
    I hope that they will also remove the videos of the male and female stripers... Its not good for children to see this.
    Aside for the Safe Browser- Web filter... Do you have other web filter?
    OK thanks for that. Honestly I am not making stories I really found so e porn videos in YouTube. Pls believe me.... Try to search on this videos Bridal Shower (2004) part 1.o of a Filipino porn movies.....so how can I report this to YouTube.
    08-04-2014 05:33 AM
  5. belodion's Avatar
    Take a look at Macafee Family Protection.
    08-05-2014 05:07 AM
  6. belodion's Avatar
    If there's anything that causes concern you can report it:
    https://www.youtube.com/yt/policyand...reporting.html
    08-06-2014 07:31 AM
  7. Johnly's Avatar
    I usually make sure my search query is concise, never has that issue....
    08-27-2014 01:12 AM
  1. Replies: 45
    Last Post: 08-07-2014, 08:37 PM
  2. How can I view photos in WeChat on my laptop?
    By Maggieooo in forum Ask a Question
    Last Post: 08-04-2014, 01:50 AM
  3. my galaxy s3 is lagging
    By Mian Mohsin Aziz Fazil in forum Ask a Question
    Last Post: 08-04-2014, 12:42 AM
  4. How to change SD Card after moving apps using link2sd
    By Zenu Khas in forum Ask a Question
    Last Post: 08-04-2014, 12:24 AM
