+ Reply
Results 1 to 5 of 5
    AC Question
    AC Question's Avatar
    Guest
    Post wifi problem
    I have several wi-fi connections already saved in my phone, for some reason it keeps searching for signals, but not connecting to none of them, it just keeps searching for Wi-Fi signal all the time. Can somebody tells me what's wrong?
  2. #2
    Almeuit's Avatar
    Posts
    Global Posts
    23,292 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: wifi problem
    It is normal to scan when it's connected.. What happens when you try that?
    Sent from my T-Mobile Note 3 using AC Forums.
  3. #3
    jucecas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have not be en able to connect. My phone keeps searching for wi-fi connections. Then it shows the ones that are available but when I tray to connect with the ones i have saved already. they ask for the password, but I do not remember them. What should I do?
  4. #4
    B. Diddy's Avatar
    Posts
    Global Posts
    78,049 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Welcome to Android Central! Are these networks all home networks, or in various locations? Review this guide and see if the tips help: http://forums.androidcentral.com/amb...-problems.html
  5. #5
    JulyLan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Maybe you can try to reset your router and find the account and password.
  1. Replies: 5
    Last Post: 01-05-2015, 11:42 AM
  2. wifi disconnecting frequrntly
    By Unregistered in forum Ask a Question
    Last Post: 12-13-2014, 07:41 AM
  3. Problem with Google Play Store
    Last Post: 08-05-2014, 02:55 AM
  4. Samsung GalaxyS4 problems
    By evxkng in forum Ask a Question
    Last Post: 08-04-2014, 08:34 AM
  5. battery problems??
    Last Post: 08-04-2014, 07:46 AM
