+ Reply
Results 1 to 4 of 4
    AC Question
    AC Question's Avatar
    Guest
    Default My Phone wont Reset .. HELP !
    this is my first post so ill try to explain everything as best i can .. I have a samsung galaxy exhibit for metro pcs and it was working perfectly fine yesterday, then i tried to go into an app and it restarted on its own (it does that sometimes so i didnt pay any mind to it) but then it did it again, and again, and again (it probably did it 20 times in an hour) i started to look for a solution to the problem on the internet and they told me to factory reset the phone, so i tried to but everytime i do it starts to do it then restarts before its finished.. i then tried a hard reset and had the same problem .. i have no idea what to do and i really need my phone .. plz help me
  2. #2
    VW Maverick's Avatar
    Posts
    Carrier
    Nitrogen OS 7.1.1 Nougat
    Default Re: My Phone wont Reset .. HELP !
    By design, a factory reset will restart twice during the process.
    Did you let it go through the reset process completely?
    If yes, did it still do the same thing?
    Mav.
    Sent from Area 51 on my Sprint LG G3.
  3. #3
    it never turned off twice when the phone restarted it went back to my lock screen and asked me to put it my password
  4. #4
    Welcome to Android Central! The battery might be starting to fail. Do you have a spare one you could try? A quick test is to take your current battery out, lay it flat on a table, and try to spin it. If it spins freely, it's bulging in the middle, which is a bad sign. But regardless, it's still worth trying a new battery.
    You could also try booting into Recovery Mode and wiping the cache partition. Follow the steps in this video, but instead of selecting Wipe Data/Factory Reset, make sure you select Wipe Cache Partition, then Reboot System Now.
  1. should i update my Galaxy S4 gt-19506 to kitkat 4.4.2
    By zeeesss in forum Samsung Galaxy S4
    Last Post: 08-05-2014, 02:50 AM
  2. my nexus 7 tablet is not working
    Last Post: 08-05-2014, 02:41 AM
  3. Replies: 7
    Last Post: 08-04-2014, 05:39 PM
  4. No Notifications From Most Apps After Hard Reset!
    Last Post: 08-04-2014, 04:47 PM
  5. Sprint Galaxy S II Epic 4G Touch Issue-Need Help
    By Josephine Lozada in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 08-04-2014, 04:34 PM
