+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default Samsung Galaxy S4 won't charge. Motherboard issue
    My Samsung Galaxy S4 got wet on my camping trip. Some water got into the charging port and it screwed up the actually port on the board. Any ideas on what i can do?
  2. #2
    warn joe's Avatar
    Banned
    Posts
    Default Re: Samsung Galaxy S4 won't charge. Motherboard issue
    Quote Originally Posted by AC Question View Post
    Well, I would say firstly you could try soaking you're device in the rice or silica get and if that again doesn't help you out then it would be better to move towards the nearest servicing centre to fix the issue with, okay I think it would be better if I feed you with the technical knowledge so you can understand what happens when the water gets inside the device. The biggest problem after the device go wet is the corrosion which I think have already started to begin, a severely damaged phone circuit board needs to be clean by spraying down the alcohol and with the help of toothbrush its gently cleaned off and once the cleaning process finished the circuit board is leave under a UV lamp to dry out. In some extreme cases ultrasonic cleaner with distilled water and then it's cleaned with alcohol to displace any moisture and in some of the case the LCD digitiser is also needed to be replaced.
  1. My samsung galaxy s5 keeps loosing its wifi connection.
    Last Post: 06-09-2015, 02:11 AM
  2. Samsung Galaxy S3 MMS messages knock out WiFi
    Last Post: 08-17-2014, 12:28 AM
  3. Galaxy S5 camera issues
    By Shabab Huq1 in forum Samsung Galaxy S5
    Last Post: 08-05-2014, 08:30 PM
  4. Prism still won't connect to wifi
    By Felicity Green Moore in forum Ask a Question
    Last Post: 08-04-2014, 10:16 PM
  5. Samsung Galaxy S 3
    Last Post: 08-04-2014, 09:58 PM
