1. AC Question's Avatar
    I bought 2 of the 6ft USB cables form Target for my S4. However, once the phone is in the LifeProof case, the charger doesn't work! It's almost like its too big?! Won't fit!
    HELP!
    08-05-2014 04:15 PM
  2. UJ95x's Avatar
    Do you still happen to have your stock charging cable? That one should work. There's no reason a manufacturer would make a case that doesn't at least work with the stock cable.
    Sent from my Galaxy S4 running SOKP 4.4.2
    08-05-2014 05:29 PM
  3. jask989's Avatar
    The stock cable works best with this case. I took a nail file to a none stock cable to make it fit.
    08-05-2014 10:49 PM
  1. S4s screen issues
    By mistyrich in forum Ask a Question
    Last Post: 08-06-2014, 03:32 PM
  2. wifi doesn't work properly on My Lg optimus G Pro
    Last Post: 08-06-2014, 12:48 AM
  3. Replies: 5
    Last Post: 08-05-2014, 11:11 PM
  4. Replies: 11
    Last Post: 08-05-2014, 06:51 PM
