1. casti184's Avatar
    S5 is awake and uses wifi at night.... pls assist
    Attached Thumbnails s5 battery drain in less than 7hrs-screenshot_2014-08-06-05-26-42.jpg
    08-05-2014 06:12 PM
  2. UJ95x's Avatar
    Have you tried rebooting your device and seeing if the drain goes away? Sometimes an app can get stuck in a wake lock, which will prevent your device from "sleeping" and kills the battery faster than normal.
    Sent from my Galaxy S4 running SOKP 4.4.2
    B. Diddy likes this.
    08-05-2014 06:26 PM
  1. S5 Native Email Crashes when using SSL and port 993...
    By SamGalaxyFan in forum Samsung Galaxy S5
    Last Post: 08-08-2014, 04:12 PM
  2. Duplicate apps in and out of folders?
    By davinaw09 in forum Samsung Galaxy S5
    Last Post: 08-06-2014, 12:22 PM
  3. samsung tab2 p3100 battery drains
    By bharadwaj in forum Ask a Question
    Last Post: 08-06-2014, 01:45 AM
  4. Which USB charger works on S4 in a LifeProof Fre case?
    Last Post: 08-05-2014, 11:49 PM
  5. Replies: 1
    Last Post: 08-05-2014, 03:06 PM
