1. amilatn's Avatar
    Guys,
    i install cm 11 for my neo v..bu battery drain fast...when i fully charged 100% at night...when i got up morning it's 70% battery standby
    SO here is the sloution
    connect your charger to phone
    then off the phone with out removing the charger
    (then phone automatically charging)
    then again on the phone with out removing the charger
    and let it to be charged 100%
    then see the battery works fine
    it's work for me....
    belodion likes this.
    08-06-2014 12:01 AM
  2. amilatn's Avatar
    144 saw..but no reply......tell is it works?
    08-06-2014 02:40 AM
  3. belodion's Avatar
    Thank you for sharing your experience, which may be helpful to others. When you refer to turning your phone off, do you mean a full Power Off, followed by Restart? If so, you are performing a Soft Reset which may well stop whatever it is that is causing abnormal battery drain.
    08-06-2014 06:04 AM
  4. amilatn's Avatar
    I mean full power Off
    08-06-2014 10:31 PM
  1. Facebook app will not work since update
    By TMorss in forum Google Nexus 5
    Last Post: 06-10-2015, 09:03 AM
  2. Can Xposed modules work on 4.4.2 if I reboot?
    By androidbrother16 in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 08-10-2014, 05:51 PM
  3. Google Play store has stopped working.
    Last Post: 08-06-2014, 12:02 AM
  4. Using Nexus 7 as a phone with a data only plan
    Last Post: 08-05-2014, 11:52 PM
  5. my samsung galazy3 is not charing
    Last Post: 08-05-2014, 10:37 PM
