Results 1 to 5 of 5
    Default Battery Saver Using Data
    When battery saver turns on [at 20%] it shuts off WiFi when 4G is not in use but if I launch an app that used the Internet, WiFi stays disconnected and uses my LIMITED data.
  2. #2
    Default Re: Battery Saver Using Data
    Welcome to Android Central! What phone are you using? Is this the built-in battery saver, or an app you installed?
    I'm using an LG G3. The batter saver built into the phone. Once it drops to 20% battery the WiFi turns off. I shouldn't have to turn it back on manually when it says "only when 4G is not in use".
  4. #4
    Just checked mine, the option is 'Turn off wifi if data is not in use'. Perhaps it's not referring to mobile data use, but to whether you're sending or receiving data via wifi at the time the battery saver activates.
    If the feature is only referring to the instant battery saver turns on then that is a useless feature that has been draining my data and costing me money. Not happy.
  1. best app to monitor data usage
    By mavericket in forum HTC One M8
    Last Post: 05-12-2015, 10:37 AM
  2. Use another android mobile remotely?
    By Richard Wells2 in forum Ask a Question
    Last Post: 01-23-2015, 07:57 PM
  3. Battery not available for xolo Q700i...
    By roshinit in forum Ask a Question
    Last Post: 08-06-2014, 12:47 PM
  4. Replies: 4
    Last Post: 08-06-2014, 10:40 AM
  5. Best app to monitor data usage
    By mavericket in forum Ask a Question
    Last Post: 08-06-2014, 10:23 AM
