1. AC Question's Avatar
    what is this problem and why is it happening?
    this had happened 5 time over the last 2 weeks
    i have had this galaxy s3 for 10 months
    i had done a factory reset but that didnt work
    help me !
    08-06-2014 03:10 PM
  2. srkmagnus's Avatar
    It's a bad battery. Get a replacement, let it fully charge then power the phone on.
    I've had the same issues and battery was the problem.
    08-06-2014 03:18 PM
  3. Tia Freemantle's Avatar
    thank you so much when just ordered a new battery
    anon8380037 likes this.
    08-06-2014 03:36 PM
  4. srkmagnus's Avatar
    You're welcome. Let us know how it works out for you.
    08-09-2014 06:21 PM
  1. Galaxy S4 GPe no longer on Play Store?
    By Ry in forum Samsung Galaxy S4 Google Edition
    Last Post: 08-11-2014, 08:13 AM
  2. Battery Saver Using Data
    By Scaughtie in forum Ask a Question
    Last Post: 08-10-2014, 08:30 PM
  3. Does the S5 come with BOTH GSM and CDMA?
    Last Post: 08-06-2014, 03:07 PM
  4. Google Calendar Sync Error Message and Duplicate Contacts
    Last Post: 08-06-2014, 02:45 PM
  5. L2 G2 - Turn off Dialing notification
    Last Post: 08-06-2014, 01:33 PM
