1. AC Question's Avatar
    My phone is works fine with no issues, Games running smooth but when charging the charger gets hot (the phone not) , btw is that normal that my phone gets charged fast? (2 hours and It's almost full battery)
    08-06-2014 04:30 PM
  2. belodion's Avatar
    The time sounds about right if you're charging from a low battery percentage. Some charger warmth is to be expected, but mine certainly doesn't get hot. Are you using the stock charger?
    08-06-2014 04:36 PM
  3. anon(9013580)'s Avatar
    I'm using this one
    Nexus 5 Charger gets hot when charging-97787d1387630508t-can-someone-show-me-what-charging-cable-nexus-5-uploadfromtaptalk1387630508357.jpg
    08-06-2014 04:39 PM
  4. belodion's Avatar
    If that's the one that came with the phone when new, it should be good. My stock charger, by which I mean the charger that comes in the box with the phone when new, has an output of 5v, 1.2A.
    08-06-2014 04:48 PM
  5. anon(9013580)'s Avatar
    mine is same like yours (5v, 1.2A), the temperature outside now is 23c It's night and kinda not hot but in the day It's 31c (I'm coming from the mid east)
    08-06-2014 05:09 PM
  6. codyoehl's Avatar
    Are we talking like can't touch it hot, or like warm, because heat is expected while charging
    Posted via Android Central App with my Samsung Galaxy S5
    08-06-2014 05:12 PM
  7. belodion's Avatar
    That's true. OP, if you can light a cigarette off your charger, you've got a problem.
    08-06-2014 05:36 PM
  1. Help Me Decide... Is there a benefit to getting the 8.4?
    By jlacck in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 08-09-2014, 07:36 PM
  2. Replies: 3
    Last Post: 08-09-2014, 06:21 PM
  3. Replies: 4
    Last Post: 08-07-2014, 09:16 AM
  4. Nexus 5 Cell Phone Reception Problems
    By MarkNexus5 in forum Google Nexus 5
    Last Post: 08-06-2014, 07:13 PM
  5. Replies: 4
    Last Post: 08-06-2014, 03:55 PM
