1. AC Question's Avatar
    I have a Samsung Model SCH-I110 (it's the monthly prepaid from Verizon and Best Buy). Not a fancy phone.
    Last night the battery completely died and had some trouble charging. I got it to charge this morning. However, now it won't turn on but says full battery. Just the Samsung name come sup. I have taken the battery out for several minutes between each attempt.
    When I hit, power/home/down I got "Warning! A custom OS can cause critical problems in phone and installed applications. If you want to download a custom OS, press the volume up key. Otherwise, press the volume down key to cancel." I hit down. Samsung came up and no change.
    When I hit, power/home/up I got some options. I selected reboot and it stayed on Samsung.
    Any suggestions?
    08-06-2014 07:32 PM
  2. codyoehl's Avatar
    It really screws up your phone if you let it run dry
    I'm not sure it can be fixed, all I know is, in the future, never let your phone's battery die
    Posted via Android Central App with my Samsung Galaxy S5
    08-06-2014 08:00 PM
  1. Replies: 1
    Last Post: 09-08-2014, 12:59 AM
  2. Can I use Icon Packs on the HTC One M7 Stock Launcher?
    By firefight352 in forum HTC One M7
    Last Post: 08-07-2014, 11:38 AM
  3. Samsung Link Platform
    By jmagid51 in forum Samsung Galaxy S5
    Last Post: 08-07-2014, 05:36 AM
  4. Replies: 1
    Last Post: 08-06-2014, 06:48 PM
