1. AC Question's Avatar
    having problems with battery from couple of days. all of the sudden it hangs up and if I try to restart the device keeps turning off. I need to connect to the charger to start the phone properly and shows 90% of battery. what can be the problem. I got the phone S4 from US and Iam using in NZ.
    08-06-2014 08:25 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The battery might be failing--can you try a new one?
    You could also try booting into Recovery Mode and wiping the cache partition: Reset: Samsung Galaxy S 4 | T-Mobile Support
    If you have an SD card, try removing it, since a corrupt card can also cause issues.
    08-06-2014 08:43 PM
  1. Ring tone being silenced on my Moto G
    By Emerogork in forum Ask a Question
    Last Post: 10-29-2014, 07:33 PM
  2. Seeking a better launcher for my Moto G
    Last Post: 08-22-2014, 01:49 AM
  3. Can't see files that were transferred from PC to my phone
    Last Post: 08-06-2014, 08:54 PM
  4. Problem with my android 2
    Last Post: 08-06-2014, 08:46 PM
  5. data usage by my jetpack
    Last Post: 08-06-2014, 06:30 PM
