+ Reply
Results 1 to 21 of 21
    AC Question
    AC Question's Avatar
    Guest
    Default Storage Problem in Micromax Canvas a120 Colours
    I just purchased a Micromax a120 Colours, i installed some apps and it went into my phone storage(fb, whatsapp), and now i cannot move it, I read many forums and found that there's already an internal storage in which we can save apps. Now the problem with my cell is that I have a PHONE STORAGE OF .89 GB(free space- 40MB, Filled space-897MB) and INTERNAL STORAGE OF 5 GB(free space-3.59GB). Now I looked for everywhere in my phone to move apps from phone storage to Internal Memory, but i am not able to find it. PLEASE HELP.
  2. #2
    Default Re: Storage Problem in Micromax Canvas a120 Colours
    Welcome to Android Central! Moving apps to SD (which usually means the "internal SD," aka internal storage) is not supported by all devices. It only moves a portion of the app anyway, so you won't necessarily free up that much space. See this guide for more info: http://forums.androidcentral.com/amb...-warnings.html
  3. #3
    How to data in indernal sd card
  4. #4
    Quote Originally Posted by AC Question View Post
  5. #5
  6. #6
    I had similar issue with Micromax A120. First I have rooted my phone with root genius.
    Second : Partition memory card with mini tool partition wizard in ext4 format with 1GB and select both partition as primary.(Other file format, viz. ext2, ext3, fat or r2fs can't be used)
    Third: Install Link2sd from play store.
    Forth: Open Link2sd and select ext4 to create mount script and reboot.
    Last: Start Link2sd and select applications which you want to link (not move to sd).
    Note: I have used 1GB for partition. You can use higher memory at your own risk. If anything goes wrong do not blame me as I did it in my own risk to my phone.
  7. #7
    Please sort out my problem
  8. #8
    I too had the same problem. I tried experimenting and found a way around it. Upgrade your firmware to "Agua Rio" based firmware. I am using Agua Rio based Cleankat. Now I have no internal memory only 5.9 gb phone memory. Click image for larger version.
  9. #9
  10. #10
    Quote Originally Posted by Saikat Dey1 View Post
    Can you please explain in detail how you managed to do this?
    Thanks in advance
  11. #11
    can u pls explain how did u do this? mixing internal sd card n phone storage to a single memory... how to upgrade firmware?
  12. #12
  13. #13
    I know how to increase the app memory without rooting....... If you have a system and internet connection I'll do it for you...... But it's Chargable.... Rs. 500/-.... I have done it successfully in my phone......contact me in watsapp no :08148719780...
  14. #14
  15. #15
  16. #16
    Default Version Problem in Micromax Canvas a120 Colours
    We need lollipop version
  17. #17
    i had given my micromax A 120 for repairing my screen.i had unmounted my 2GB memory card.now wen i mounted it its saying unfortunately android media storage has stopped working.i cant see my songs and images in music and gallery.but its there in my file manager.what is the problem?
  18. #18
  19. #19
    Quote Originally Posted by Prasoon Swarup View Post
    Thanks in advance
  20. #20
    Can you please explain how to upgrade to
    "Agua Rio" Firmware?
  21. #21
    how to upgrade firmware to agua rio based in Micromax A120 for internal storage issue..?
  1. Automatic ring silencer in Moto G ?
    By Emerogork in forum Ask a Question
    Last Post: 04-02-2015, 06:23 PM
  2. messaging app missing in samsung s4
    Last Post: 08-09-2014, 04:47 PM
  3. Stuck in CWM recovery after restoring!!!!
    By MohaCario in forum Ask a Question
    Last Post: 08-08-2014, 04:27 PM
  4. card problem
    Last Post: 08-07-2014, 10:38 AM
  5. Android overtakes Apple in global web traffic
    By androidphguides in forum Ask a Question
    Last Post: 08-07-2014, 10:26 AM
