+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Question Need Kies 3 for my Samsung Note 3 - Help!
    Somehow I must have accidentally uninstalled the Kies app on my Samsung Note 3 phone (Verizon). I don't recall doing so,but it is no longer there and I cannot get the phone to sync with my computer.
    I have tried and tried to find a Kies (3.0v preferred, but any may work) app for download, but I cannot find one. All I can find is the Kies download for the actual PC. I did that, but without Kies on my actual phone, it's useless!
    Anyone know where I could find & install a Kies app on my actual phone? Hoping I don' t have to do a factory reset to get it back!
    Thanks SO much!
  2. #2
    Default Re: Need Kies 3 for my Samsung Note 3 - Help!
    Hello. I have never used or downloaded the app. I just connect with the usb cable when I get to my pc.
    However you may need to do it remotely if that's how it works.
    I think sadly it has been ended, well Kies air at least. If you cannot find the app in Applications Manager - All, it is not in Samsung Apps, now called Galaxy Apps, or Play Store.
    I am sure you can get recommendations for pc remote apps software. I think Side Sync is one, but I haven't tried it.
    See here :
    http://forums.androidcentral.com/sho....php?p=3806220
    Sent from my SM-N9005 using Tapatalk Pro
  1. Samsung Galaxy S
    By Makayla Kirk in forum Ask a Question
    Last Post: 03-31-2015, 11:43 PM
  2. Will my HTC One M7 work on T-Mobile?
    By dino v in forum T-Mobile
    Last Post: 01-17-2015, 03:23 PM
  3. Need help
    By flavius24 in forum Samsung Galaxy S5
    Last Post: 08-08-2014, 11:26 PM
  4. Notifications for Non-Android Wear Apps
    By George H Martin in forum LG G Watch
    Last Post: 08-08-2014, 06:59 PM
