+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Angry Nexus 4 - microphone don't work on calls
    But with other programs it works and during call enabling loud speaker call... the mic does work.
    The phone had been wiped. Factory secting wipe just few days ago.
    From the time it did worked till now, no additional software had been installed. And no use of headphones at all (not even for music)
    Found this program on play store:
    https://play.google.com/store/apps/d...honeroutingfix
    and tried to use it to restore audio path but doesn't seem to work.
    Month ago, it happened the same and that program fixed it by resetting audio path.
    Android version is 4.4.4 stock google... no modding... never done any modding on that phone
    What concern me is..
    1) how to fix it
    2) how is possible that it happen, what trigger that problem?
    thanks a lot for anyone that could give me a hint... and to anyone that just is reading
  2. #2
    Default Re: Nexus 4 - microphone don't work on calls
    What other apps seem to work with the mic? Remember that most apps that use the mic are using the secondary mic, not the phone mic. The speakerphone also uses the secondary mic. My suspicion is that your primary phone mic is faulty.
  1. Replies: 1
    Last Post: 08-09-2014, 08:07 PM
  2. Samsung Galaxy Exhibit Stuck On Boot Loop
    Last Post: 08-09-2014, 02:58 PM
  3. Replies: 1
    Last Post: 08-09-2014, 12:45 PM
  4. Group messaging on Samsung Galaxy S5
    By deebeen21 in forum Ask a Question
    Last Post: 08-09-2014, 11:28 AM
  5. how do I Transfer photos from nexus 4 to macbook
    Last Post: 08-09-2014, 11:08 AM
