+ Reply
Results 1 to 3 of 3
    AC Question
    AC Question's Avatar
    Guest
    Default Nexus 7 will not charge when docked
    I place my Nexus 7 on the ASUS dock and the status immediately change to 'Charging' but it will continue to discharge at the normal rate. If I remove it from the dock (while 'not' charging) the status will stay as 'charging'. I have to turn it off and on to reset that
    I actually have to turn off the tablet to get it to charge in the dock.
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,771 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Nexus 7 will not charge when docked
    They could be an app or service interfering with it charging without a reboot. Have you reset the device to see if it clears the problem?
  3. #3
    Adriaan VanderWalt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The charging problem seems deeper. I reboot (shut down, wait 30 sec, start) and then place it on the docking station. It recognizes the docking station immediately but do not charge even when indicating it is charging. I found out that if I then remove it from the docking station, the tablet still thinks(?) it's docked, I have to reboot to get the 'charging' status to change. I even connected it to the normal charging cable but it did not actually charge until I rebooted.
    Update, My tablet is regressing. Now it will not charge even on cable unless it is turned off first. It will charge once it has rebooted but without any charging indication.
  1. Replies: 1
    Last Post: 08-17-2014, 01:04 PM
  2. Nexus 5 & Android 4.4.4...worth to try again?
    By Gino Guillermo in forum Google Nexus 5
    Last Post: 08-13-2014, 04:19 PM
  3. s view cover wireless charging
    By Barry Test in forum Verizon Samsung Galaxy Note 3
    Last Post: 08-13-2014, 02:49 PM
  4. Will I be able to keep my unlimited data?
    Last Post: 08-09-2014, 04:29 PM
  5. Replies: 0
    Last Post: 08-09-2014, 03:46 PM
