1. RKnotes's Avatar
    I've a new low entry model phone with Android kitKat (Celkon A35K - India) and it has all low end specs for internal storage (allows certain apps to be on SD card) and battery life is not good!
    So the challenge is to adjust the usage of apps to maximize the battery life
    Just switched to Google Now launcher and it is great.. but I suspect it drains battery trying to pull info for cards (My loca
    I use 3 widgets -- Calendar, Analog clock, Google Keeption reporting is On)
    On a general note, do any or some widgets drain battery (a la Gadgets in Windows) or it is specific to how they're built?
    Thanks!
    RK
    08-12-2014 07:18 AM
  2. the tall guy's Avatar
    Thanks!
    RK
    It would depend on the widget to be honest, some widgets don't do anything until you interact with them, others - such as weather widgets refresh every hour or so and that would use up battery. I would imagine tho, that even the smallest of widgets would play some factor in the battery, but not by much
    08-12-2014 09:43 AM
  1. galaxy s3 loss of signal or worse
    By brokens3 in forum Samsung Galaxy S3
    Last Post: 08-15-2014, 12:00 PM
  2. My LG mobile needs three tap to go to any application
    Last Post: 08-12-2014, 06:14 PM
  3. Folder as per Galaxy Plus or Google Icon
    By RoystonB in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 08-12-2014, 08:01 AM
