1. AC Question's Avatar
    I downloaded the usb drivers and windows media player 10 then attempted to connect the device to the pc. It recognizes it when I have it as a PTP (that is windows explorer shows two folders), but when I switch it to MTP, there is nothing. I am using a pc that is running Windows 5.1 (ancient stuff), could that be why?
    08-12-2014 11:00 AM
  2. Chris Guittard's Avatar
    Just a little more info, I do see where it says that it will only work with XP or later, but am not sure if that is just for synching with media player or to access SD card. I have hooked it up in the past just by downloading the files.
    08-12-2014 11:40 AM
  1. Changing messaging font size - LG G3
    Last Post: 10-06-2016, 12:13 PM
  2. Getting pics from SD Card to show on LG G3
    Last Post: 03-29-2015, 09:17 AM
  3. battery problem
    By edie in forum Ask a Question
    Last Post: 08-13-2014, 12:45 PM
  4. Samsung Apps problems
    By Rowdee1 in forum Android 2.3 Gingerbread
    Last Post: 08-12-2014, 10:57 AM
  5. problem with emoticon
    Last Post: 08-12-2014, 10:53 AM
