1. AC Question's Avatar
    My phone died, so I charged it and it said "BLANK SD CARD OR UNSUPPORTED FILESYSTEM." Then asks me to format it. I have a bunch of pictures from my vacation how do I get them back? My computer says the same as well. If I format will I have all my pictures still? I have a galaxy note3 and a 2 Gb SD.
    08-12-2014 12:56 PM
  2. SpookDroid's Avatar
    If you format you will lose all data. You say your card won't read on a computer either? It can be that the card itself got corrupted.
    You can try to repair it using file checking tools on a PC. Just make sure that you DON'T format the card anywhere until you've exhausted all of your options. Again, formatting will make you lose all information in the card.
    08-12-2014 01:04 PM
  3. Chiplg's Avatar
    Do a search for "Corrupt SD card recovery" You will find multiple PC utilities that claim to recover your corrupted data. I cannot speak to the effectiveness of any of these apps, but they are your best bet for cheap. I tried several a few years ago on a compact flash card that got corrupted on a photo shoot I did as a favor with no luck. Thank goodness it was just a favor and not for cash. Sometimes corrupted is forever. Good luck. There are also data recovery experts, but they charge a fortune.
    When you get it going again, I recommend setting your phone to backup you pictures to the cloud automatically.
    08-12-2014 09:32 PM
  1. Getting pics from SD Card to show on LG G3
    Last Post: 03-29-2015, 09:17 AM
  2. My Droid Razr HD won't update!
    By Axellionn in forum Ask a Question
    Last Post: 08-15-2014, 10:06 PM
  3. please help centura help asap
    Last Post: 08-12-2014, 12:41 PM
  4. Need help getting to stock recovery
    By Tyler Frank in forum Ask a Question
    Last Post: 08-12-2014, 11:22 AM
  5. my question
    Last Post: 08-12-2014, 10:53 AM
