+ Reply
Results 1 to 2 of 2
    AC Question
    AC Question's Avatar
    Guest
    Default Nexus 7 Charging Problem
    My Google Nexus 7 tablet has decided to give up on life. It was having trouble charging, so we ordered a new battery, thinking that the battery was going bad. Well, the battery arrived, I installed it, and... no change. The battery came with about 70% already on it, but it's doing the exact same thing that the last battery was doing - not charging when plugged in, and even slowly discharging over time, even when powered off.
    So I did what any person would do and turned to trusty Google.com! Or maybe not so trusty... Apparently it's is quite common for Nexus 7 owners to experience battery trouble. However, none of the recommended "fixes" worked with my tablet. In my searchings, I discovered an app called Battery Monitor Widget that allows me to view exactly what my battery is doing, including letting me see how many mA were going through the battery. The Google Nexus 7 is supposed to have well over 1000mA going into it while it's charging, but mine has -300mA to -500mA. What?
    So basically it seems that the charger is drawing power FROM the tablet instead of putting power INTO it. I have tried plugging the tablet into my laptop via USB to see if it has a faulty charger. But that made no difference, it was still discharging. So then I switched out the cord with the one that goes to my phone and tried it with both the charger and USB on my laptop. No change.
    Now the battery is at about 40%, so I unplugged the charger, and removed the battery to save it from completely draining. Anyone have any ideas as to how I can fix my tablet?
  2. #2
    SlateSpider's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexus 7 Charging Problem
    Nevermind! My computer-savvy brother fixed the problem for me! It was something to do with the connection between the ribbon and the port and it didn't fit together just right.
  1. Phone locked problems
    By Mia2400 in forum HTC One Max
    Last Post: 02-25-2015, 12:30 PM
  2. Problem with palying songs
    By Avan WJ in forum LG G3
    Last Post: 08-17-2014, 09:13 AM
  3. Nexus 8 to Feature 4GB RAM?
    By Murph5150 in forum Google Nexus 9
    Last Post: 08-13-2014, 07:50 AM
  4. S4 battery drain whilst charging
    By Spring Roll in forum Samsung Galaxy S4
    Last Post: 08-12-2014, 07:11 PM
  5. Printer Problem with Tab 3 !0.1
    Last Post: 08-12-2014, 07:05 PM
