1. AC Question's Avatar
    i am having problem when people cant hear me they find me as if i am talking from far away.caller from the other end of my call cant hear me properly Call is a basic thing which a phone provides and if that doesnt work properly then it is a big flaw.please help me out and give me the best solution.
    08-13-2014 07:56 AM
  2. the tall guy's Avatar
    You might have a dodgy phone, I had the Nexus 5 for a few good months and never noticed any call issues. Are your call volumes up to their max? are you making sure you are speaking directly into the microphone?
    08-13-2014 08:54 AM
  3. Rukbat's Avatar
    There are a few possibilities.
    Check the little mic hole. (Look in the book or an on-line manual to find it if you don't know where it is.) See oif there's any lint or dirt in the hole. There shouldn't be.
    You could have a defective mic. You could have the wrong mic being used (internal mic used when you're using the speaker). There could be a defective component on the motherboard. (The volumes you can set have nothing to do with how the other party hears you, only with how you hear them.)
    At worst you have a defective phone, and it would be covered under the warranty. The solution for that is to have the phone replaced.
    08-13-2014 11:39 AM
  1. HTC one m8 camera problem (night photos)
    By Creed1989 in forum HTC One M8
    Last Post: 12-12-2014, 04:08 AM
  2. Anyone use phone as GPS in car
    By Murphy5111 in forum LG G3
    Last Post: 10-21-2014, 07:19 AM
  3. Email In Box
    Last Post: 08-13-2014, 11:54 AM
  4. video problems ( Asus me172v)
    By Unregistered in forum Ask a Question
    Last Post: 08-13-2014, 10:07 AM
  5. need help with nexus 5 operating system
    Last Post: 08-13-2014, 04:19 AM
