+ Reply Subscribe
Results 1 to 5 of 5
    AC Question
    AC Question's Avatar
    Guest
    Default Droid DNA Message's problems
    Since today my messages have been acting up. Basically every time i try to go and text someone in their thread, it goes to the message thread and just says loading for hours. Normally it just says loading for about 1-2 seconds then i can see the messages, but now it just sits there, loading. I've already rebooted the phone 3 times, fastboot and regularly as well as cleared the cache. Any help?
  2. #2
    Default Re: Droid DNA Message's problems
    You say you've cleared the cache...do you mean apps or system? If the former, a Cache Partition wipe may just fix it, although to be honest I'm not very confident that it would. But no harm trying.
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    6,108 Global Posts
    ROM
    X-Note7.0.1
    Check with your carrier's tech support. They could be having problems. If all the people you're having problems with are on the same carrier, but not your carrier, have one of them check with her/his carrier.
  4. #4
    The funny thing is that it's only with a few threads. Some it works with and others it doesnt. As for the carrier, it appear to be happening to just my phone.
    Edit-i was the guest asking the question
  5. #5
    Welcome to Android Central! Is it crucial for you to keep all of your existing messages in your messaging app? If not, go to Settings>Apps>All, select the Messaging app, and tap Clear Cache and Clear Data, then Force Stop. Now open the app again and see if you can text these people. Keep in mind that this will clear out all of your existing message threads.
  1. IMEI Problem
    By bryandesrosiers in forum General Help and How To
    Last Post: 08-13-2014, 02:13 PM
  2. problem in nexus 5
    Last Post: 08-13-2014, 12:39 PM
  3. Replies: 1
    Last Post: 08-13-2014, 11:21 AM
  4. Google Sync Problems - Contacts and Photo Backups
    By Anselm Lee in forum Ask a Question
    Last Post: 08-13-2014, 11:15 AM
  5. video problems ( Asus me172v)
    By Unregistered in forum Ask a Question
    Last Post: 08-13-2014, 11:07 AM
