1. AC Question's Avatar
    Hello all,
    I recently installed an Xposed module that was supposed to change the status bar look in some way. I set it to cutter mode, and now my phone is unusable. Whenever my phone starts, com.android.systemui crashes repeatedly and the status bar won't appear. After about 2 seconds, I can't do anything touch related. I'm thinking not being able to use touch is because of the pattern lock loading repeatedly.
    Whenever I try to boot into recovery, I get the yellow Verizon triangle.
    I have a Verizon Galaxy S3 running 4.4.2, rooted using towelroot.
    USB debugging is enabled.
    All my files I wanted saved are already backed up to a computer already.
    Is there any way I can access stock recovery again, disable the lock screen from computer, or uninstall the module through the computer?
    08-14-2014 09:15 AM
  2. Golfdriver97's Avatar
    I am inclined to think there is an ADB command for a reset. I am not sure though.
    08-14-2014 09:27 AM
  1. unlocking hard locked sony xperia j help?
    By trius90 in forum Ask a Question
    Last Post: 08-14-2014, 12:08 PM
  2. Samsung S3 Mini Value Edition Issues, please help!
    By KleineHerz in forum Ask a Question
    Last Post: 08-14-2014, 09:59 AM
  3. Comprehensive List of App Notification Icons Needed please?
    Last Post: 08-14-2014, 09:36 AM
  4. help open my phone
    Last Post: 08-14-2014, 05:30 AM
  5. Help
    By cookiesmonster in forum Ask a Question
    Last Post: 08-14-2014, 02:43 AM
