1. saqib mansoor's Avatar
    hi
    i have tablet pc android 4.2.2 brand alps .total internal storage is 510 mb every time i download it gives eror of runing out of space .
    how should i come out of this problem /
    how should i use external sd card as a internal storage ?
    help me
    thank you
    08-15-2014 03:26 AM
  2. st1114g's Avatar
    Since your device has has so little memory, you should get at least 18GB memory card, imop.
    Once you insert it, you can go in settings-> apps and go down the list of app and set them to use memory card as a storage. Not all apps do that so you might still find yourself with a memory error. Most Third party apps allow you to transfer them to the memory card, but some native apps have to stay in internal storage to function, so if you don't use an app you could clear the memory and disable it, if allowed by the system, so it doesn't use much space...but that is a temporary solution because as they are updated, apps rarely use less space than before.
    But if I were you, and can afford it, I would just get a new device.
    08-15-2014 05:30 AM
  1. lg g3 folder shortcut problem...
    Last Post: 03-31-2015, 10:44 PM
  2. apps to sd problem (rooted)
    By Unregistered in forum Ask a Question
    Last Post: 08-08-2014, 07:43 PM
  3. problem with screen HTC Inspire 4g
    By ojle dojle in forum Ask a Question
    Last Post: 08-08-2014, 01:59 PM
  4. calling problem in grand 2
    Last Post: 08-08-2014, 12:28 PM
  5. Replies: 0
    Last Post: 08-08-2014, 10:39 AM
