Results 1 to 5 of 5
    nimdass's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs down Low sound :( NEeed help
    Hi guys,
    I racently bought a Bose SoundTrue Headphones for my galaxy s4 I9500. But the volume is low even at the highest settings. Tried some mods for that but nothing worked they just boosted the speakers. Any advice??
    Thx.
  2. #2
    belodion's Avatar
    Posts
    Global Posts
    19,849 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Low sound :( NEeed help
    There are some apps that promise to increase volume. Whether they'd damage your phone in any way I've no idea but you could look into them at least.
  3. #3
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Kitkat
    Quote Originally Posted by nimdass View Post
    Hi guys,
    Thx.
    Hello.
    Check your settings to see if you have some sort of "safe volume" option on. That's to prevent you from turning the volume up too much and damage your ears. That lowers the volume output and may be the culprit.
    Sent from my HTC One XL using AC Forums mobile app
  4. #4
    N4Newbie's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What are you using as a media player?
    If you are willing to switch to PowerAmp you can use its Replay Gain function to significantly boost output volume.
    nimdass's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for reply guys
    Im using PowerAmp for player and I listen uncompressed flacs, replygain didnt work for me .s
    Im considering fiio e6 for an amp but will it damage my phones as belodion said?
    And safe listening is off .
    Thx
    [UPDATE]
    Switched to Perseus Kernel. Sound is great now.
  1. Replies: 10
    Last Post: 09-07-2016, 06:27 PM
  2. Can't get sound when looking at a video on facebook
    Last Post: 09-08-2014, 08:04 PM
  3. Music Effects and Personalized Call Sound
    By PainFX in forum Samsung Galaxy S5
    Last Post: 08-15-2014, 06:31 PM
  4. [Help] how do i get out of this
    By dontae joseph in forum Ask a Question
    Last Post: 08-15-2014, 01:15 PM
  5. sound notification
    Last Post: 08-15-2014, 11:12 AM
