Results 1 to 8 of 8
    Default My S5 will not work with Sprint Airave while in LTE/CDMA mode
    My Galaxy S5 will not connect with my Sprint Airave (network Extender) if my network mode is set to LTE/CDMA. I have to manually change it to CDMA. I had an Apple 5 and I never had to change my network mode back and forth to connect with my Airave and it was always on LTE.
    Does anyone else have this problem and found a solution? I called Sprint and they tell me to manually switch it. This is a real pain in the @$$!!!
  2. #2
    Default Re: My S5 will not work with Sprint Airave while in LTE/CDMA mode
    yup i have the same problem with my s5. So with cdma only theres no Lte, what good is that,
    Now i have to manually switch when i leave the house? I was hopping the switch from Apple
    was a no brainer..Hmm
  3. #3
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default
    Does it automatically switch back to CDMA/LTE? Or do you manually change it when you go from place to place?
    Sent from my Galaxy S4 running SlimKat 4.4.4
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Quote Originally Posted by vndragone View Post
    You could use Tasker to switch it automatically. Or you could bring the phone into Sprint and ask them to resolve the problem.
    You have to manually switch it. I tend to forget to switch it back to CDMA when I get to the house and miss phones calls. Sucks!
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Jason MacArthur View Post
    If it's in the CDMA/LTE mode it should be auto switching though...
    That is what I thought but I called Sprint support and they tell me that I have to manually switch it myself to get it to work with the Airave. Ridiculous.
  8. #8
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Oh, OK. I think the Network Extenders for T-Mo and Sprint (maybe the other two) only boost their respective 4G signals. That would explain why you have to use CDMA only.
  1. Flipboard work around
    By Arthur62 in forum Samsung Galaxy Tab Pro 12.2
    Last Post: 10-20-2014, 08:22 PM
  2. 'Network not Available' Changed SIMM Cards
    Last Post: 08-19-2014, 06:57 PM
  3. pebble stuck in headphone jack
    Last Post: 08-15-2014, 05:50 PM
  4. Can't access certain websites on my data, UNLESS I'm on a Wi-Fi connection
    By Waqar Qureshi in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 08-15-2014, 04:42 PM
  5. Samsaung Galaxy s5 volume increase after text message?
    Last Post: 08-15-2014, 04:00 PM
