1. bshorm's Avatar
    Hi, I've had my s3 just over a year and had no problems until now. It was charging really slowly and never got to 100%. I replaced the charger and it now charges fine but the battery is draining much quicker than it used to, it seems to be dropping a couple of percent every few minutes I'm using it and even when I'm not using it. Any suggestions?
    Attached Thumbnails samsung s3 battery draining quickly-screenshot_2014-08-16-15-25-34.jpg   samsung s3 battery draining quickly-screenshot_2014-08-16-15-25-26.jpg   samsung s3 battery draining quickly-screenshot_2014-08-16-15-43-46.jpg
    08-16-2014 10:11 AM
  2. Golfdriver97's Avatar
    Looks like you have a few wakelocks, Your cell signal doesn't seem so great, and Google Play services accounts for 19% of the 65% drain, meaning about 12% of your total drain is from Play Services.
    Have you tried a restart?
    08-16-2014 10:38 AM
  3. bshorm's Avatar
    By restart do you mean a factory reset? I haven't done that yet. Is there a way to stop the wakelocks?
    08-16-2014 10:50 AM
  4. UJ95x's Avatar
    No, just a reboot. That usually fixes wake locks
    Sent from my Galaxy S4 running SlimKat 4.4.4
    08-16-2014 11:47 AM
  5. Rukbat's Avatar
    And if it doesn't, install Wakelock Detector to see what's keeping the phone from sleeping.
    08-16-2014 12:35 PM
  6. bshorm's Avatar
    Thanks for your help. Ran wakelock detector overnight and google apps seemed to be a problem. Have stopped sync on those so will see if that makes a difference.
    08-17-2014 03:39 AM
  7. UJ95x's Avatar
    How did it go?
    08-18-2014 02:17 AM
  8. JulyLan's Avatar
    Hi.I think maybe there is something wrong with your battery.I have even encountered the same problem as you,but what the difference is the battery can be charged full in half an hour but can also run out of in 20-30 minutes,especially when you surf the internet.My friends told me maybe the battery was aging.so I have bought two another new battery from the website.Things go well,my phone can work fine.But now I have sent the phone to one of my families.
    08-18-2014 02:37 AM
  1. s3 stuck at booting screen
    By androbada525 in forum Samsung Galaxy SIII I9300
    Last Post: 12-17-2014, 08:24 PM
  2. 100% charged battery & my Samsung S4 will not turn on.
    Last Post: 09-15-2014, 09:57 AM
  3. samsung galaxy note 3 sound issue
    By hamzahmalas in forum Samsung Galaxy Note 3
    Last Post: 08-20-2014, 06:39 PM
  4. S3 Mini white boot text
    By John Mendoza3 in forum Samsung Galaxy S3 Mini
    Last Post: 08-17-2014, 12:36 AM
  5. Help! Galaxy S3 won't charge
    Last Post: 08-16-2014, 01:11 PM
