Results 1 to 2 of 2
    CommanderHusky's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Samsung Galaxy S4: Camera problem
    When I write to my SD Card, the camera app doesn't start recording until a few seconds after pressing the record button and when I stop recording nothing happens. It just continues to record without actually writing more footage to the card then I loose it, exit the camera app and it's as if nothing happened. I used chkdsk on my card (no problem) and the H2test but my (surprisingly cheap) class 10 sandisk sdhc from ebay doesn't have any other problem than very low writing speed (0.5mb/s) and I haven't had ANY problems until ~3 months after updating to KitKat 4.4.2 (oh how I despise this update). Anyone with the same problem?
    Ps. This doesn't happen if I save to device, I'm afraid to save to device then put onto the SD Card because my sd card has been corrupting my recent vids/pics
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Default Re: Samsung Galaxy S4: Camera problem
    I'd guess (don't hold me to it, I'm just making a semi-educated guess, but my Note 3, running 4.4.2, saves and stops to the SanDisk card just fine) that you have a bad card. Contact SanDisk (look on their site for tech support). They're very easy to work with (which is one reason that's the only card I buy).
  1. FS/FT Samsung Galaxy Tab Pro 12.2 Mint, $385 Shipped
    By radyoactive in forum Marketplace Archive
    Last Post: 08-19-2014, 09:49 PM
  2. Stupid galaxy s3
    Last Post: 08-17-2014, 03:05 AM
  3. No space on Samsung Galaxy S5?
    Last Post: 08-17-2014, 01:31 AM
  4. samsung galaxy note 3
    By hamzahmalas in forum Samsung Galaxy Note 3
    Last Post: 08-16-2014, 08:19 PM
  5. WiFi problem
    By Ahmad Alajami in forum Ask a Question
    Last Post: 08-16-2014, 06:33 PM
