+ Reply
Results 1 to 8 of 8
    Brandon Warrington
    Brandon Warrington's Avatar
    Guest
    Default S5 battery voltage question.
    Stock battery is 3.85v and the aftermarket is 4.4v. Will the 4.4v battery cause damage?
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default Re: S5 battery voltage question.
    Are you buying an extended battery?
    It's recommended that you use a battery that is the same in terms of voltage, but I don't think it will be too much of an issue.
    Sent from my Galaxy S4 running SlimKat 4.4.4
    bwar85 likes this.
  3. #3
    bwar85's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No extended battery. Just spares to be free of the charging cable.
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    And it's not the OEM battery? You can get those pretty cheap online. I'd recommend using those over third party batteries.
    bwar85 likes this.
  5. #5
    bwar85's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The problem is that I noticed the voltage being 4.4v after months of use. Guess ill buy batteries with the correct voltage if that is recommended.
  6. #6
    bwar85's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OEM is 3.85v and Aftermarket non-Samsung is 4.4v
  7. #7
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Quote Originally Posted by bwar85 View Post
    Ah, OK. If you've had no issues so far I wouldn't be too worried about it.
  8. #8
    jcarlson65's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey guys. The nominal (average) discharge voltage of a 1 cell lithium battery is 3.85v while the peak (fully charged) voltage is 4.4v This is slightly higher than other Lithium batteries that I've used for high discharge applications. Normally peak voltage for LiPo is 4.20v, LiIon 4.10v. In other words third party batteries are definitely compatible and run the same voltage. Look on your charger block once, it'll say something like 1.0A/4.40v
  1. My Galaxy S5 will not shutoff
    By TBONEgotCHA in forum Ask a Question
    Last Post: 08-18-2014, 04:23 AM
  2. Phone frozen + battery stuck
    By Melissa Makic in forum Ask a Question
    Last Post: 08-16-2014, 11:53 PM
  3. few droid questions
    By Anthony Srdar in forum Ask a Question
    Last Post: 08-16-2014, 11:43 PM
  4. Replies: 1
    Last Post: 08-16-2014, 11:27 PM
  5. Replies: 1
    Last Post: 08-16-2014, 11:26 PM
