+ Reply
Results 1 to 7 of 7
    AC Question
    AC Question's Avatar
    Guest
    Exclamation Android setting problem
    Okay. So I disabled the built in apps that I rarely use to make space on my tablet. After that, the settings stopped working. Everything else still works except the settings. I was going to try and do a complete reset where all of my data would get erased since I'm not too attached to anything on my tablet, but the only way I know how to do so is to go into settings. Is there any way I could reset my tablet from a computer? Or anyway I could get the settings to work again? Thank you!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,673 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Android setting problem
    What tablet do you have?
  3. #3
    I have the Q8 tablet that runs with kitkat 4.4 (This is still the same person...and I'm sorry if that's not a good answer. I'm new to android.)
  4. #4
    This is the one I have.
  5. #5
    Posts
    Global Posts
    32,673 Global Posts
    Carrier
    Quote Originally Posted by Kalea Thiele View Post
    Welcome to the forums.
    Try this:
  6. #6
    Unfortunately that didn't work
  7. #7
    While powered off, try pressing and holding the Power and Vol Up buttons, or Power and Vol Down. Keep them down until you either see the Recovery menu, or the tablet ends up on the homescreen. If it boots up normally to the homescreen, then try some other combination.
  1. Tons of problems with my Note 3
    Last Post: 09-21-2014, 11:37 PM
  2. problem with hot spot
    By vsbunker07 in forum Droid RAZR MAXX Rooting, ROMs, & Hacks
    Last Post: 08-18-2014, 06:11 PM
  3. Messages+ settings problem
    By IBMJunkman in forum Samsung Galaxy S5
    Last Post: 08-17-2014, 07:57 PM
  4. Problem with wifi on my android
    Last Post: 08-17-2014, 04:39 PM
  5. HTC One Car Mode tunein radio problem
    Last Post: 08-17-2014, 02:59 PM
