1. AC Question's Avatar
    Hello,
    I wanted to root my S4 so I went with the guide from anuj petal on youtube( also androidrootz dot com) but it didn't work basically it told me to place superuser.zip(SU) on my phone and to update my phone with it. So i placed SU on my phone, did the odin stuff with the right .tar file, went to the recovery menu but I got the normal menu, not the clockwork menu. Me not paying attention( I know I am a moron) went to the 2nd option( i believe update from internal file and chose SU file. it was installing it, said error and crashed. Now when I try to turn it on it shows me the first screen saying samsung g3 and I9300 and then I get a black screen. Can someone please help me? I tried factory reset from the same menu but it didn't do anything
    08-17-2014 05:47 PM
  2. TheJerkinator's Avatar
    It as the apply update from external storage. Now it doesn't work anymore. Can i but the original samsung software on a SD card and use that to update it with because I think I updated my software to superuser(which is like exchanging a car for a tire)
    08-17-2014 05:49 PM
  3. TheJerkinator's Avatar
    yeah sorry it's about the galaxy S3
    08-17-2014 05:55 PM
  1. Replies: 9
    Last Post: 03-19-2015, 09:48 PM
  2. Mobile data keeps disconnecting on htc one m8
    By Unregistered in forum Ask a Question
    Last Post: 08-17-2014, 09:44 PM
  3. Water Damage No Signal On/Off
    Last Post: 08-17-2014, 05:43 PM
  4. Novice ! help, messed up rooting
    By pratmodi in forum Moto G Rooting, ROMs, & Hacks
    Last Post: 08-17-2014, 05:33 PM
  5. Problem with wifi on my android
    Last Post: 08-17-2014, 03:39 PM
