1. Afterlife737's Avatar
    Hi,
    I have a Z1 and am running the SOKP 4.4.4 ROM and have been getting terrible battery-life compared to over Roms. Why is this ? Why does Android OS tak nearly 3/4 of my battery life ? What can I do about this ??
    Thnx !
    Edit : Just to clarify, this is with Mobile Data off at all times and WiFi on only for the last few hours... And I hardly used the phone today since I was away :/ Really gutted about this Never had Android OS take so much up...
    08-18-2014 02:32 PM
  2. UJ95x's Avatar
    Has this been an issue since you installed the ROM or did it start recently? It might be a bug with the kernel they're using. Last I checked, SOKP didn't have a stable release of 4.4.4 so it might be worth switching to an older version of SOKP (4.4.2 was pretty good when I used it) or changing ROMs altogether until they do.
    08-18-2014 02:40 PM
  3. Afterlife737's Avatar
    Hi - yeah it looks like the Kernel.. I will probably flash back to CM11 M9 snapahot - that was real stable and had gr8 batterylife
    08-19-2014 08:49 AM
  4. Dave Leyland's Avatar
    How can you tell if its a problem with the kernel? Which other ROM should I switch to?
    08-19-2014 08:55 AM
  5. UJ95x's Avatar
    Let me know if that was the fix
    Sent from my Galaxy S4 running SlimKat 4.4.4
    08-19-2014 10:02 AM
  6. UJ95x's Avatar
    The"Android OS" drain is mostly from kernel processes. If their kernel is buggy, it can cause the excessive drain like we see in OP's post.
    Are you having it as well?
    08-19-2014 10:04 AM
  1. Strange problem with S3 not turning on
    By TDAYz in forum Samsung Galaxy S3
    Last Post: 08-18-2014, 07:10 PM
  2. ssh to android with X11/GUI ?
    By gargavf in forum General News & Discussion
    Last Post: 08-18-2014, 03:24 PM
  3. Sd card problem on samsung tab 3
    By thatkid96 in forum Ask a Question
    Last Post: 08-18-2014, 03:15 PM
  4. Android os is gone!
    Last Post: 08-18-2014, 01:51 PM
  5. JRE for Android?
    By Galane in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-18-2014, 01:35 PM
