1. AC Question's Avatar
    Having problems getting any game to play on Frodo C64 and also need help with ePSXe.
    May as well start with the PSX emulator: I expected the Tuvva's game pad buttons to be able to be used with ePSXe but I can't see how. The touch screen buttons work OK but I'd like to use the physical ones if possible - is it?
    As for Frodo I just cannot get any game to be recognised - which is odd as even my PS2 emulator recognises that 'Thrust' is there. I have around a 4.7 MB unzipped games file (if I did it right) in my Android>OBB file and also elsewhere, both locations only finding the Frodo top level folder. I tried looking at Vice but too complicated, and I would consider paying for Mobile C64 if I thought I could get it to work, which I doubt I can.
    When I bought the Tuvva one reviewer said if you didn't understand Android you won't get what you want from this machine, and that seems to be the case - totally ignorant of all things Android, me.
    I also got Pretendo for DS games, Professor Layton being the one I wanted to play - but that was also a rubbish experience.
    I'm quite happy with the PSX emulator, apart from controller issue, but not with anything else I have tried. As a cheapskate I like free but I'd consider paying for what I need if that's the only way to go.
    Any advice at all would be much appreciated, especially on how to get Commodore 64 games on my Android device.
    Cheers.
    08-18-2014 04:24 PM
  2. Mark Daly1's Avatar
    Bump.
    08-19-2014 09:40 AM
  1. Play Store problem
    By Steven Boardman in forum Ask a Question
    Last Post: 10-31-2016, 10:04 PM
  2. Unable to active mobile network on UNLOCKED NOTE2
    By onlyforu in forum Ask a Question
    Last Post: 08-29-2014, 05:58 AM
  3. Yellow tint on screen
    By ShAdoWSKy in forum LG G3
    Last Post: 08-26-2014, 06:09 AM
  4. Battery drain problems - Android OS 70% + ?!
    By Afterlife737 in forum Ask a Question
    Last Post: 08-19-2014, 10:04 AM
  5. i cant change the video quality of youtube videos on note 3
    By hamzahmalas in forum Ask a Question
    Last Post: 08-18-2014, 03:44 PM
